My timing chain is jammed
Old Oct 20, 2025 | 02:45 PM
monkfe's Avatar
Default My timing chain is jammed
So I was replacing my valve stem seals today (4L AJ6)....went as expected and I got them all installed. But sometime during the install, the timing chain dropped one one side and now is jammed between the sprocket and the tensioner. I played with it for sometime and couldn't get it to move. Is there a way to unbolt the bottom of the tensioner (passenger side) to allow it to move a bit? I found one bolt that I thought was it, but no dice. I assume the tensioner if bolted from the front. My manual doesn't seem to show it, at least on the page I was on. Thanks in advance gents.
Old Oct 21, 2025 | 05:23 PM
equiprx's Avatar
I think you might need to loosen up the valve train.
Sorry to be the barer of bad news.
Old Oct 22, 2025 | 07:31 AM
monkfe's Avatar
Ordered a 1 5/16 socket to turn the crank...hopefully this resolves it. Anyone know if there is a specific TDC mark (like on a Chevy small block) on the crank pulley? I can't say I see anything specific in this regard.
Mrseam
Feb 21, 2024 11:06 PM
434MHz
Sep 9, 2021 01:05 PM
ronski
Feb 14, 2013 04:05 AM
TN8Shooter
Sep 30, 2012 09:16 PM
linconlsv8
28
Feb 20, 2012 12:37 PM
