NAB3580DA spark plug for emissions A
Friends, do You know a replacement for the original part number NAB3580DA?
It is a spark plug for XJS MY 1988 5.3 US version, emission A.
Thank you very much in advance.
I use NHK BR7 EFS. But there are lost of others.These are the specifications:
https://www.ebay.co.uk/itm/301517682...3ABFBMrpD_oN1m
Just make sure you buy plugs for the HE V12; not the pre-HE!
Specifications for NGK BR7EFS
- Thread diameter: 14mm
- Thread reach: 17.5mm
- Seat type: tapered
- Hex size: 16mm
- Tip configuration: non projected
- Construction: Standard construction
- Terminal type: Solid
Thanks everyone for the responses. I use BR7EFS, but as Greg writes, I'm looking for the difference between nonHE and HE spark plugs (which is NAB3580DA, according to Jaguar specifications, a HE spark plug). I found DENSO T20EPR-U and NGK BR7EFS (3177).
The question is whether they are for HE engines.
