New To Forum-1991 xjs wheel prob?????Please HELP!!!
Old Mar 1, 2009 | 05:24 PM
ArmyJag's Avatar
The Lightning bolt is telling you that there is a electrical fault, it should say 1,2 or 3 to tell you which panel to be looking at. If the abs fault, and the lightning bolt happened at the same time they could be very related.
Old Mar 1, 2009 | 06:21 PM
joe wilson's Avatar
Check all associated electrical connections and ABS fuses. Check pad wear, you should only have to remove wheel to do this. Note how grooved your rotor is. If the rotor is bad, you may need a brake job on the rear anyway, always do both sides. Brakes are very important! It's your last line of defence from hitting defence
H20boy
Dec 24, 2024 03:23 PM
Rivguy
Dec 4, 2020 07:55 AM
PMKimpton
Aug 3, 2019 08:22 PM
Armor6
Sep 14, 2015 07:56 PM
metalmarty
Sep 11, 2015 07:05 AM
