Normal Alternator Voltage 90 V-12
Old Jan 27, 2014 | 07:54 AM
mikebaker3's Avatar
Default Normal Alternator Voltage 90 V-12
My 90 has the Bosch Alternator. Even when the battery has a low charge, voltage never raises above 14v, just above the line separating discharge and charge on the barrel gauge. Alternator belt had too much slack, but has been tightened.
Is this a normal condition?
Old Jan 27, 2014 | 10:22 AM
warrjon's Avatar
If you mean the gauge on the dash this would be what I would expect. When the battery charge is low the gauge will read a higher voltage and as the battery comes to full charge the voltage will drop to around 13V.
If you check it with a meter the Alternator should be somewhere around 14.4V when charging and 13.8V when not charging. These are approximate as the actual reading will vary a few hundred millivolts depending on the meter and other variables.
Old Jan 27, 2014 | 11:35 AM
Doug's Avatar
Yeah, sounds about right to me.
The dashboard gauges are not always as accurate or responsive as we'd like, but, still, I don't see anything to be concerned about in your case.
hoodun
Nov 20, 2022 02:35 PM
Rocky15
Sep 28, 2015 04:59 PM
DBAM
Sep 25, 2015 12:00 AM
vincent661983
Sep 10, 2015 05:52 PM
jaguarbill
Sep 5, 2015 11:43 AM
