O2 sensors
Old Apr 3, 2012 | 04:40 PM
Per's Avatar
Per
Default O2 sensors
My '90 with Marelli displays symptoms of dying O2 (Lambda sensors). Are these bog standard sensors? The wiring diagrams show three wires: Ground (Black), Pre-heating (Brown/Grey) and Signal +ve (Green). However, the three wire sensors available off the shelf have Black for the signal and two white for the pre-heating (+ and -). Are the Jag sensors special or the same as some other brand? (Presumably the Ford influence didn't show until the facelifted 6 litre.)
I don't know if the thread is similar either, metric/UNF etc?
Old Apr 3, 2012 | 05:59 PM
Doug's Avatar
Later Jags had some unique sensors but your 1990 still uses the bog standard 3-wire sensor
Old Apr 5, 2012 | 03:07 PM
Per's Avatar
Per
Good (inexpensive) news
But how do I determine which of the two pre-heating wires is the ground? Or does it get additional ground through the body of the sensor? I.e. zero Ohms between body and the GND wire?
Old Apr 9, 2012 | 12:55 PM
WalkerTech's Avatar
Per,
I am a product specialist with Walker Products, a worldwide manufacturer and distributor of O2 sensors.
You can connect either of the two white wires to the ground loop in the original sensor harness. The heater circuit has a separate ground. I hope that helps.
Old Apr 10, 2012 | 06:36 AM
Per's Avatar
Per
Thanks, makes it nice and simple
Old Aug 22, 2012 | 10:43 AM
Per's Avatar
Per
Question
Originally Posted by WalkerTech
Per,
According to the wiring diagrams sensor and heater shall have common ground and sensor signal and heater ground is taken further. However, looking at the existing sensor it has two white wires llike the replacement, going into a two pole connector. Then one black wire has its own high quality screw type connector going on into a blue wire in the harness. I am wondering if the diagram is wrong and that the two white wires are the heater wires. The black one is the sensor and the sensor has its ground through the housing and thereby the exhaust -> engine -> strap -> chassis -> battery.
Anybody know for certain?
EDIT: I found another wiring diagram which shows the config I have. The blue one is O2 signal, and the two white ones are the heater. Case closed
Old Aug 22, 2012 | 01:12 PM
M90power's Avatar
ive got a set of HE single wires for sale.
Poet
Feb 7, 2025 02:18 PM
carl purchase
Oct 14, 2015 06:14 PM
Dave1109971
Sep 30, 2015 11:04 PM
Doug S
Sep 30, 2015 02:03 AM
