Oil Leak
Old Jan 22, 2009 | 06:53 PM
PSU 98's Avatar
Default RE: Oil Leak
Oil leak could be from a valve cover gasket. The complexity of the repair depends on how difficult it is on your model to get the valve cover off to replace the gasket.
Valve seal replacement is a moreinvolving repair. The blue smoke you see would likely be from oil slipping past the seals and burning off into the exhaust. So unless it was literally pouring out of there, it wouldn't cause a big leak.
Either way make sure to keep an eyeon engine oil levels until you can get the problem fixed!
Boeingtravel95
Sep 14, 2015 05:01 PM
jaggermang
Sep 8, 2015 07:07 PM
OkieTim
Sep 8, 2015 04:48 PM
Dymaxxion
Sep 4, 2015 02:40 PM
OkieTim
Sep 2, 2015 12:48 PM
