oil leaks
Old Mar 8, 2015 | 08:28 PM
drbill's Avatar
Default oil leaks
Just picked up a 1994 4.0 L coupe aj6 engine. Seems to have a few oil leaks:
1. front crank seal and/or timing cover
2. oil cooler lines at filter housing (o-rings)
3. pinion seal on diff
I think 2 and 3 are fairly easy to replace. What about #1? Is this a common place for a leak and hints to replace?
TIA,
Bill
Old Mar 8, 2015 | 08:46 PM
Doug's Avatar
I have no helpful hints on #1....other than to do #2 and THEN see if #1 is worth really doing! I did #2 on my XJR and the improvement was so dramatic that the other leaks became insignificant. The leaking O-rings made quite a mess and made the other leaks look worse.
As for #3, the pinion seal, it really isn't all that easy. Well, it's easy to replace but making the job come out correctly isn't always easy. You gotta making absolutely 100% certain that the pinion nut is reinstalled to exactly the same torque/position as before removal. If not, pinion bearing failure is likely in the near future
Old Mar 8, 2015 | 09:22 PM
manwich66's Avatar
+ 1 to that,leave the pinion alone.Ours weep,fluid seems good between changes.
Both our cars weep,but get the proper O rings for the oil cooler lines.
Huge difference.
Front seal,yup.
weepy timing case,yup.
leaky front head gasket,yup.
all fixable.
clean it and see....
cheers,Jim
Boeingtravel95
Sep 14, 2015 05:01 PM
jaggermang
Sep 8, 2015 07:07 PM
OkieTim
Sep 8, 2015 04:48 PM
Dymaxxion
Sep 4, 2015 02:40 PM
OkieTim
Sep 2, 2015 12:48 PM
