Oil seal track and water thrower removal - how to?
Old Feb 11, 2018 | 02:23 PM
wpawlo's Avatar
Default Oil seal track and water thrower removal - how to?
Hi All,
I am working on the rear suspension on my XJS.
I dismantled almost all hub and carrier pieces. I am stuck on the oil seal track ( C24791 ) and water thrower ( C20813 ).
I found tons of useful information how to press the carrier off the hub, bearings off the carrier and how to assemble everything together. But I could not find any trace of anyone having dealt with these two parts.
I am afraid that there is no other option than bend/brake the water thrower. Maybe you know a better solution?
Regards, W
Jaguar XJS; Oil seal track and water thrower before removal
Old Feb 11, 2018 | 04:03 PM
Jagsandmgs's Avatar
That oil seal track/spacer is literally just sitting there. It’s not screwed in, press fit, or otherwise attached. Turn the while thing upside down and whack it with a hammer... maybe it will fall off.
Old Feb 12, 2018 | 01:58 PM
wpawlo's Avatar
I have given it a couple of upside down whacks. With no success. Anyone who could share experience? Maybe its only rust that holds it in place.
I doubt it is not pressed - it must be tight since the other side of the oil seal track is sealed. With seal on the outside and too much play on inside would not do much sense.
eurolat
Feb 12, 2018 03:35 AM
Feffman
US Midwest
Sep 1, 2015 07:29 AM
Feffman
Motorsports
Jul 3, 2015 10:07 AM
Aussie Steve
Oct 24, 2014 05:54 AM
