Oil sending unit trouble
Old Jul 5, 2019 | 05:07 PM
G Man's Avatar
Default Oil sending unit trouble
I have 95 XJS 4.0. The threads in the block are cross threaded and I can’t get the oil sending unit in. Does anyone know the exact thread size tap that I need to fix the threads? I’ve been told it is 1/8 inch pipe thread. But NPT is 27 per inch. British pipe thread is 28 per inch. I’ve tried using a thread gauge and I can’t tell the difference.
HELP
Old Jul 6, 2019 | 03:56 AM
70 Views but 0 Replies as I write.
I've moved your question from General Tech Help to XJS forum. If anyone has the answer, members here with the same model will be able to help.
Old Jul 6, 2019 | 04:30 AM
ALL my catalogues, etc show that switch WITH a washer as a seal, so that would be NPT, since BSP is a taper thread and NO washer is used.
I thought I had an old switch in the shed, but thought wrong, found other forgotten stuff though.
Take your sender to the "store", whatever your market calls them, that sells thread taps and dies, and get a thread tap to suit.
Old Jul 6, 2019 | 08:39 AM
G Man's Avatar
Thank you.
Old Jul 6, 2019 | 06:39 PM
Vee's Avatar
Vee
https://www.jaguarforums.com/forum/x...d-size-201518/
The title of the thread literally indicates it will tell you what you’re looking for....
zubizar
Dec 27, 2013 01:03 AM
Jagxjs
Dec 7, 2012 04:24 AM
f-cano
Apr 23, 2012 11:25 AM
robhair
XJ40 ( XJ81 )
Jan 31, 2012 09:20 PM
dperry
May 20, 2010 05:28 PM
