Outboard Disk conversion - Yes or No????
Old Dec 27, 2011 | 08:29 PM
warrjon's Avatar
Default Outboard Disk conversion - Yes or No????
Ok, I have to decide if I go ahead and convert to outboard disks or not. I have everything necessary except the handbrake levers.
Fors as I see it
- Vented rotors with better cooling.
- Removes any issue with overheating Diff output seals.
Against
- Increased un-sprung weight approx 10kg, albeit with a lower frequency of oscillation.
- Need to source handbrake levers or fabricate something.
- Single piston slide calipers vs twin piston.
I guess what I am looking for is a discussion and input especially if you have experience with both IB and OB on the XJS.
Old Dec 28, 2011 | 12:20 AM
Death Kitten's Avatar
what did you get the parts off of? just curious.
Im all for it. ease of maintance.
Old Dec 28, 2011 | 12:54 AM
warrjon's Avatar
I bought a complete XJ40 rear end. The driveshafts and hubs fit the older cage rear with minor mods.
Outer fulcrum shaft in XJ40 is small diameter so XJS LCA's need to be bushed, and the handbrake is different, other than that they will bolt up no problem.
jagtoes
Apr 22, 2016 07:37 AM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
GoNavyMike
Sep 28, 2015 08:56 AM
Samheath100
Sep 20, 2015 08:21 AM
