Picked up a parts car - Have some questions on swapping parts
Old Oct 8, 2022 | 08:37 PM
alabbasi's Avatar
Default Picked up a parts car - Have some questions on swapping parts
So I have a 1994 XJS V12 Convertible. When it bought it, the roof was slashed and consequently, the interior is not in the greatest shape.
I bought a 1996 6 cylinder parts car that caught fire under the hood. The interior and soft top are near perfect condition.
1) The first thing I want to do is unbolt the soft top and swap it over. I the very same thing on my R107 500SL and it was easy, but that was a manual top car.
Has anyone done this job?
2) I want to swap the seats, but this will require me to remove the door panels so that I can access the power seat controls. If anyone has instructions for this, I'd love to hear from you.
3) The blower motor is always on with my V12 car. What do I need to swap out on this car to make that stop?
Old Oct 9, 2022 | 11:40 AM
equiprx's Avatar
If you are just swapping out the seats, you should not have to remove the door cards to access the seat controls.
Perhaps I don't understand what you mean.
Old Oct 10, 2022 | 11:40 AM
alabbasi's Avatar
Hi there,
I guess the question here whether I can you pop the electric switch panel off the door so I can put power directly to the pins in order to move the seats. As the car was in a fire, much of the wiring harness under the hood is burnt so trying to power the seats from the battery in the boot is a non starter.
Old Oct 10, 2022 | 12:16 PM
ptjs1's Avatar
Disconnect the plugs under the seats and power it straight from there.
Paul
Old Oct 11, 2022 | 11:43 AM
alabbasi's Avatar
Thank you, that's a good idea. I have a probe somewhere which should do the job
Old Oct 11, 2022 | 01:16 PM
ptjs1's Avatar
As regards your other 2 questions:
1. Remember that the convertible hood uses tension cables. When you remove the parts car hood, you may want to change those cables
3. The infamous Darlington Transistors can cause the blowers to permanently run. Read up on this and consider changing them.
Paul
Old Oct 12, 2022 | 01:03 AM
Jagboi64's Avatar
Here is the circuit and a parts list: https://www.jag-lovers.org/xj-s/book/acblower.htm
mtfd49
Jul 25, 2022 07:12 AM
egovreau
Apr 11, 2019 01:50 PM
Jaguar Dre
XJ40 ( XJ81 )
Jun 27, 2017 06:04 AM
jagway
US Western
Apr 27, 2015 09:25 AM
bluetone
Dec 13, 2013 09:49 PM
