Please help me find the starter relay.
Old Jan 7, 2023 | 10:22 AM
jani129's Avatar
Default Please help me find the starter relay.
My car is a 1977 Jaguar XJS V12, left hand drive. It was in a fire and is in a rather sad state. I set out to fix it.
When I switch on the ignition, I hear a click. When I try to crank, it gives another click. But I don't know where it is coming from. Where is the starter relay?
Circuit diagram
Engine bay overview
Left side of firewall, this is a LHD car.
Right side of firewall.
Left side toward front
Right side toward front, some relays.
Old Jan 7, 2023 | 10:28 AM
jani129's Avatar
Maybe the reason I can't find it is that it isn't in the car. But I do hear a click. Also the fuel pump doesn't turn on which is kind of lucky otherwise I would spill petrol. I guess I can disconnect it once it starts working. I did remove the fuel from the tank for safety consideration.
Old Jan 7, 2023 | 10:39 AM
jani129's Avatar
Maybe this one huhh
Old Jan 7, 2023 | 04:18 PM
jani129's Avatar
Thanks for reading this. I found everything about the starter relay that I wanted to know for the time being. I just wanted to crank it. I found the wire coming up from the starter solenoid, touched it to the +12V thick wire and it cranked ok. I image I should do this from time to time to avoid the engine sitting in the same position for too long. Until I can fix it and drive it.
Parker 7
XJ40 ( XJ81 )
88
Dec 13, 2022 11:02 AM
John Briscella
Jun 17, 2022 11:59 AM
bult360
Sep 7, 2021 08:09 AM
Rob Benjamin
Nov 7, 2020 01:27 AM
