popping sound
Old Sep 3, 2013 | 06:38 PM
anziobridgehead's Avatar
Default popping sound
(1982 xjs) Hi, my 82 xjs has a new noise. And why not, it's new month right?. Somewhere near my rear right (LHD) wheel, I'm hearing a popping sound when I accelerate and decelerate. I was thinking trailing arm bushing if that's what it's called on a Jag. Has anyone else heard this "pop" before?
Old Sep 3, 2013 | 07:05 PM
AllanG's Avatar
Could be, might also be one of the axle u-joints or a worn/loose rear cage mount?
Does it do it from rest in drive and reverse?
Cheers,
Allan
Old Sep 3, 2013 | 09:52 PM
Allen, yes, I believe it does. I was thinking u-joint originally. I was aware of axle joints, but that's exactly what it sounds like. I think it might even pop during gear changes also.
Old Sep 4, 2013 | 05:45 PM
Allen, what or should I say where is the "rear cage mount"? What should I be looking for and where exactly should I be looking? Any pics would be real helpful.
Old Sep 4, 2013 | 06:34 PM
AllanG's Avatar
The rear cage or crossmember or subframe as it may be called, houses the rear suspension and differential. It is bolted to the body via 4 rubber mounts. These mounts can become worn or loose and might be worth a look.
Here is a diagram from Jag. http://www.jaguarclassicparts.com/uk...-mounting-rear
Cheers,
Allan
Old Sep 4, 2013 | 09:18 PM
Allan, Thanks, I'll check them out.
JagBrian
Feb 27, 2019 07:08 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
wcourt3010
Sep 23, 2015 01:06 PM
JagBrian
Sep 21, 2015 07:17 PM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
