power steering resovoir
Old Oct 2, 2008 | 06:21 PM
yonhottscott's Avatar
Default power steering resovoir
I have a very slow leak in my power steering, so i was told to keep the power steering fluid topped up until i could get the money to get the steering fixed. I have just realized that after about 20 minutes of searching, i can not find the power steering fluid reservoir. I was looking on the right (when sitting in the car) front fender, in the engine bay (as i thought that was a likely place, and i can't find anything.
any help would be arreciated, thanks.
Old Oct 2, 2008 | 07:20 PM
ontherun's Avatar
Default RE: power steering resovoir
We have a 90 XJS v12 thepower steeringdoes not have a seperate reservoir,. it's on the pump,. on the driver side bottom..you have to look past the air cleaner and hoses...But we don't know what year you have it could be someplace else...L
Old Oct 2, 2008 | 07:34 PM
thanks for the info, i have the 90 xjs as well, so, i'll look there. i really appreciate it. i was looking on the wrong side, i guess.
Old Oct 3, 2008 | 11:17 AM
Keith's Avatar
On my 95 6.0, you can barely see it, drivers side, down low also. You'll need a flashlight. The upper radiator hose is in the way, and I have to remove the hose in order to check the fluid. Unless you have very small hands, its difficult to get the cap off also. The guy at the local gas station will never get to it while filling your tank. Good luck. Keith
Old Oct 3, 2008 | 06:56 PM
thanks all =)
i found it, and with the help of a REALLY long funnel was able to get some fluid in there, so she sounds better now.
(i'm a really skinny guy so getting there wasn't an issue, it was the worry of burning myself *laughs*)
thanks again, guys.
Bcrary3
Sep 26, 2015 10:36 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
1964Daimler
Sep 9, 2015 11:28 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
