programming a new remote
Old Jan 19, 2014 | 09:01 AM
rossstein's Avatar
Default programming a new remote
the valet switch on my 93 xjs is located on the column, how do i program a new remote?
Old Jan 19, 2014 | 09:19 AM
Welcome to the forum rossstein,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to XJS forum. The Advice / Feedback & Suggestion Center is for posts about the forum and not for tech questions.
Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jan 19, 2014 | 09:55 AM
AllanG's Avatar
Try this.
1993-94 XJ6 cars:
1. Turn ignition key ON.
2. Turn security (valet) switch OFF
3. Turn ignition key OFF.
4. Turn security switch ON.
5. Cycle security system switch ON/OFF rapidly 4 times (within 5 seconds).
6. Press each transmitter so a total of 5 confirmations are heard.
Old Jan 22, 2014 | 05:18 PM
Spillwaybob's Avatar
Hi Allan,
My '94 XJS V12 does not have a security switch. Two remotes came with the car but only one works. The other one had a dead battery which I replaced but it still does not work. Do the remotes loose the programing when the battery goes dead? If you know how to program this model, I could try to get it working. Thanks for your time.
Bob (Spillwaybob)
Old Jan 22, 2014 | 07:20 PM
AllanG's Avatar
Originally Posted by Spillwaybob
Hi Allan,
Bob (Spillwaybob)
Hi Bob,
Yes Jaguar removed the security switch in the 94MY so you and I are out of luck
The wiring for the switch is still available though, it is under the center console. Here is a link to a thread made by Spikepaga. He links to a video he made showing how to connect the switch. It is easy to do and should get you sorted provided the remote is actually working!!
https://www.jaguarforums.com/forum/x...s-video-85375/
Swagguar
Sep 30, 2015 01:34 PM
redxk8
Sep 30, 2015 08:18 AM
zdrapec
Sep 25, 2015 05:49 AM
kevinl
Sep 24, 2015 08:25 PM
