Push Brake pedal blows fuse & turn signals don't work
Old Aug 19, 2023 | 02:04 PM
Patrick 1989 XJS's Avatar
Default Push Brake pedal blows fuse & turn signals don't work
I installed a new turn signal arm assembly and plugged into connecter and everything worked fine. I started working on interior lighting and headlamps and now the brake pedal blows the fuse and the turn signals dont work until I install a new fuse and don't stp on the break. Is the brake pedal be pushing on the limit switch and is the limit switch normally open or closed?
Any ideas?
Pat
Old Aug 27, 2023 | 12:35 PM
kansanbrit's Avatar
Any ideas?
Pat
I would try pulling the brake light relay first and see if the fuse still blows.
jrb53
Feb 9, 2023 10:38 AM
CalsJag
Jul 8, 2018 07:24 PM
Regular rick
Oct 16, 2015 04:31 PM
macboots
Jul 26, 2012 10:52 PM
