Radiator insert nut?
So the banjo bolt "nut insert" I stripped attempting to put new copper washers in.
I have no idea what that's called. And where to find to solder a new one in.
Any ideas?
Any ideas?
What I would try first is to identify the thread, then see if a thread insert (helicoil or similar type of thing) is available for that thread, then use the insert to restore the thread.
Greg
Greg
Retapping will not work, usually, because there is not enough metal there anymore to tap. That is why a thread insert is needed. It is pretty straightforward to do. for example:
http://www.bing.com/videos/search?q=...5438CE1EEBE51E
Greg
Greg
Greg
as of typing this it's been three days since I put a Helli coil on the banjo receiving part of the bolT. and so far so good.
I also used these upgraded seals for the copper seals from XK's. these things are genius!!! and I noticed you don't have to compress them as crazy as the copper washers since their rubber sealed.
17-2000 - Stat-O-Seal 3/8" Stat-O-Seal, Upgrade For C4146
there also for the oil galley feeds up in the tappot blocks. .
Luke5324
Dec 5, 2015 01:50 PM
FS[SouthernMidWest]: Bolt on Wire Wheels from XK8
49Markvman
Nov 8, 2015 05:20 PM
