Radiator / water pump removed - opinions wanted
Old Jun 8, 2020 | 09:19 AM
Asdrewq's Avatar
Default Radiator / water pump removed - opinions wanted
I removed the rad & water pump recently; reason being I wanted to make sure everything was 100%.
Can anyone provide opinion on the following pictures - particularly the red gelly-like stuff that was behind the waterpump going to the LH bank - is that fairly typical? Looking beyond that stuff & into the block, it looks fairly clean, but i'm not sure what's normal.
The radiator, at least externally, looks ok, but there are those white marks where the fins connect. Do you think the rad shot? I put a cheap bore scope down the hose connections; the internals look absolutely fine with no buildup (see pics) - maybe too clean for it being the original radiator.
Any opinions/experience most welcome!
Old Jun 8, 2020 | 09:34 AM
garethashenden's Avatar
The red stuff looks like it’s been clogging the passage from the pump to the bank. I’m not sure what it is, but it shouldn’t be there.
Old Jun 8, 2020 | 12:56 PM
Daim's Avatar
Somewhere aalomg thr lines, someone mixed antifreezes. That is crystalisation, as the mixtures mix and react.
Give the engine a good rinse with fresh tap water. Fill it nor ally, drive a while with it, then empty. Refill, drive, empty, refill,... You'll get rid of that stuff easily. It just needs to 'dilute' itself.
Old Jun 8, 2020 | 01:05 PM
brinny's Avatar
It looks like the orange oat stuff . Used in xk8 and not to be mixed with others. As for the radiator have you any leaks?
RaceDiagnostics
Aug 27, 2021 06:57 AM
pk4144
Nov 24, 2019 11:42 AM
Grumpydude
Oct 20, 2019 04:17 PM
rgsaz
Apr 24, 2019 11:05 AM
Brake buster
May 6, 2008 10:04 AM
