Radio wiring question
Old May 28, 2018 | 06:36 PM
treborefir's Avatar
Default Radio wiring question
Hello,
I'm installing an Alpine cde 164BT into my 1994 xjs and have one wire that's not computing with me. Its the wire on the Alpine for "illumination". There doesn't seem to be an appropriate wire in the Jag harness. It's supposed to allow the lights to dim, which I think is a good thing. I am thinking that I can hook this up to one of my display wires (the ones going to the factory radio surround for the vent controls). Do I even need this?
Any thoughts?
Thanks in advance
Old May 28, 2018 | 07:16 PM
Doug's Avatar
You want to to hook this wire up to the instrument light circuit so the radio can be dimmed/brightened along with the instrument lights. I don't have a '94 wiring diagram to give you a specific wire color or ocation
This is a good feature; not all aftermarket radios have it.....and the radio displays are often way too bright as a result
Old May 28, 2018 | 07:26 PM
Forcedair1's Avatar
Originally Posted by treborefir
Hello,
Any thoughts?
Thanks in advance
If you can just temporarily power up the radio, see if the illumination works without connecting that wire. If the radio lighting works without that wire being connected, then I'd connect the wire to an existing car wire that carries the car's illumination power to see if the radio lights get dimmed. I believe this wire may be like a sensor for the radio to automatically dim its lights when the car lights are turned on.
Good luck,
Old May 28, 2018 | 07:27 PM
treborefir's Avatar
That was exactly my feeling also. I just needed someone to agree with it. I've installed a few aftermarket stereos but never ran into the illumination wire before, and yes the others have been too bright at night.
Old May 28, 2018 | 07:28 PM
Forcedair1's Avatar
You beat me by 10 minutes, Doug ..LOL (seems to me more like 1 1/2 minutes)
Cheers,
ynotfl62
Jan 1, 2016 12:46 AM
Michael Anderews
Dec 26, 2011 11:24 AM
sam12345
Jul 10, 2007 02:29 PM
