Rattle - gearbox or clutch?
Old Oct 12, 2022 | 03:45 AM
leep123's Avatar
Default Rattle - gearbox or clutch?
Hi all,
Have an issue with my 1990, XJS 3.6 manual which has done 139,000 miles on (I believe) original clutch and gearbox.
Car drives fine although clutch biting point is low. After car has warmed up and clutch pedal is pushed hard to the floor, I get a rattle / chatter from gearbox / clutch area and a slight vibration. Noise level not constant i.e., it comes and goes. Makes no difference if gearbox is in neutral or any gear. No noise with clutch pedal released.
Trying to decide if this is a clutch issue (release bearing?) or something internal inside gearbox before planning remedial work.
Thoughts appreciated and thanks for reading.
Cheers,
LeeP
Old Oct 12, 2022 | 05:15 PM
Mikekeay's Avatar
From experience I would suggest Thrust Bearing.
Mike
Old Oct 13, 2022 | 08:01 AM
ptjs1's Avatar
+1 for the release bearing, Lee. You'll change that anyway when you replace the clutch.
Paul
Scotts120fhc
XK120 XK140 XK150
May 5, 2023 09:21 AM
leep123
Aug 21, 2022 12:24 PM
Mgbams
May 14, 2017 01:46 PM
x300drew
Jun 7, 2015 02:25 AM
mrdobsie
May 3, 2011 04:29 AM
