Raw Oil Smell
Old May 25, 2022 | 02:22 PM
jordanmc's Avatar
Default Raw Oil Smell
Hi everyone, I have gone through my 92 XJS V12 pretty thoroughly and fixed what I believe to be all the oil spots that leak. Half moons, Banjo washers etc. On hard acceleration or high revving spirited driving I am still getting what I believe to be a raw oil smell. I can not find any area’s that are leaking. I am wondering if connected some of the vacuum hoses incorrectly could that cause negative pressure in the cam covers or something???
Any ideas would be appreciated
Old May 25, 2022 | 03:11 PM
BenKenobi's Avatar
Look at the breather front left on bank B and associated pipework. You sure it is engine and not power steering or transmission oil odour - unfortunately the internet hasn't perfected scratch n sniff
You may consider also that the smell is just fine and the steering column seal is no good - i.e. theres a leak allowing the smell into the car.
There is supposed to be a slightly negative pressure in the engine itself.
Old May 29, 2022 | 07:59 PM
Brewtech's Avatar
All Jags smell like oil
Old May 29, 2022 | 11:11 PM
Yep, kind of normal.
Since there has been leaks, the residual oil may still be sitting in places yet to be washed down.
Driving is as designed, things heat up, air rushes to these areas, and oil stink it what you have.
Oil on the exhaust, all the way to teh rear cradle, is a common source of that stink.
The breather capsule/filter in that snout Ben mentioned should be ditched. They are 99% clogged, the engine cannot breath properly, and havoc is soon a friend.
None of mine run that filter, and no ill affects after 30 years.
Some more suggestions in that stickie at the top, just in case you missed it.
Old May 30, 2022 | 09:28 AM
YES!
This is how you know you have a Jag!
If you want a car that doesn't smell like oil, get a new Camry.
Old May 30, 2022 | 11:33 PM
AND
Dont forget that oil leaks were all designed and implemented by Jaguar as part of the Rust Protection Program.
Worked well until the later cars.
Defender99uk
Aug 15, 2023 01:24 PM
Dannyaspect34
Oct 11, 2022 03:50 PM
razorboy
Jan 27, 2021 06:15 PM
BrentGardner
Oct 11, 2013 03:53 PM
BigWill
Jan 2, 2008 05:48 AM
