Rear windows will not go ip
Old May 22, 2022 | 07:52 PM
scottpeterd's Avatar
Default Rear windows will not go ip
Removed the pump last fall to,replace the seal. All connectors and relays back in.
i have switched the pump to manual. The pump runs in both directions, but the windows will not go up.
Thoughts?
Old May 23, 2022 | 07:13 AM
ptjs1's Avatar
Default Rear windows will not go up
scottpeterd,
I'm sure you probably know this, but there is an 8-second time delay on the rear windows going up. So you'd have to press the switch for at least 10 seconds to get the windows to rise.
Good luck
Paul
Old May 23, 2022 | 10:40 PM
Paul,
I had forgotten. Too many toys to remember their idiosyncrasies.
Thanks for the reminder. It worked
nickg112
Sep 14, 2017 01:54 PM
4jagspeter
Aug 2, 2016 07:46 PM
motomental
Aug 16, 2013 06:55 PM
RJag
Aug 26, 2011 08:38 AM
