Relays
Old Jun 9, 2015 | 07:22 AM
Zolomoro's Avatar
Default Relays
My 96 XJS Convertible will not start. Suspect bad fuel pump but want to verify before replacing. Wiring diagram shows fuel pump relay has two resistors in it. Are all relays the Same?
If not, where can I find the replacement number?
Old Jun 9, 2015 | 07:33 AM
Doug's Avatar
Good that you checked. All relays are NOT the same! Some appear the same at first glance but may have diodes or resistors (as you discovered) or different terminal designations.
I don't know the part number off hand, sorry. Others will chime in
Old Jun 9, 2015 | 09:44 AM
Zolomoro's Avatar
Thanks, Doug.
hoodun
Nov 20, 2022 02:35 PM
jagent
Jun 5, 2022 02:18 PM
asleach2889
Oct 1, 2015 01:53 AM
Mark SF
Sep 28, 2015 01:51 PM
