Remove Cruise Control or Not
Old Apr 16, 2024 | 11:36 AM
Patrick 1989 XJS's Avatar
Default Remove Cruise Control or Not
Some of the cruise control parts have been removed from my car. It would be easy to reinstall the missing part. I don't plan on using the cruise control. Should I fix the system or remove the broken bellows and other parts to open up the engine for cooling and better looking engine bay? Will it cause any issues with the running of the car by removing the bellows and other parts?
Old Apr 16, 2024 | 12:47 PM
jal1234's Avatar
Removing it won't cause problems. Just be sure to plug the related vacuum lines. The cable going from the bellows to the throttle pedal assembly can be removed, or coiled up.
Jon
Old Apr 17, 2024 | 11:34 AM
Thank you for the information. I think I will remove the unit and coil up the cable.
tberry6686
Dec 8, 2013 01:27 PM
Davexjrv8
Nov 29, 2011 09:38 AM
thuffner3
Jun 7, 2011 05:30 AM
JagWatcher
Dec 2, 2007 12:32 AM
