Replace old ignition coil
Old Nov 17, 2014 | 11:05 AM
93xjs6cyl's Avatar
Default Replace old ignition coil
I just bought a 1993 XJS Jaguar convertible with 93,000 miles on it and I need to do some maintenance on it. So, I have replace the plugs, cap, rotor, plug wires and now I'm looking for a new ignition coil. From what I have seen available locally for this car, it seems the primary resistance is anywhere from 0.6 to 1.5. ohms. My service manual says 0.9 to 1.1 ohms. primary resistance. I need to make sure I get the right one for my car. Are the values of the local coils too far out of range?
Old Nov 17, 2014 | 02:16 PM
sidescrollin's Avatar
generally that spec is what it needs to be within to operate, since the other coils are inside the OEM spec you should be fine.
Old Nov 17, 2014 | 02:30 PM
93xjs6cyl's Avatar
Default Old coil
Sidescrollin, Thanks for your feedback. I think I will go with the Bosch brand.
Forcedair1
Sep 8, 2025 01:57 PM
JarodL
Mar 7, 2024 01:39 AM
cissdm
May 3, 2016 06:02 AM
XJsc-guy
Nov 23, 2015 01:56 PM
KarimPA
Sep 3, 2015 07:32 PM
