rims will they fit
hey guys will jaguar xk8 rims fit my 1992 xjs v12 here is the rim size 2002 JAGUAR XK8 FACTORY OEM WHEELS RIMS 18 X 8, 18 X 9
i seen them on ebay for $600 for the set is this a good price?
Other thing to consider is the design of the suspension isn't designed for rims that tall, the car will have a much greater tendency to tramline, or follow the grooves and ruts in the road than with smaller rims. 16" is generally considered as tall as you want to go to avoid that effect.
Yes the narrower tyres will have less tendency to tramline.
My rims are 16X8 BBS originally for an XJ40 with +33 offset. It is illegal in Australia to use any type of spacer (unless it was manufacturer fitted) To change the offset of the front rims I had a 13mm spacer machined and fixed into the back of the rim with CS screws, thus becoming part of the rim. This is a much safer way than 13mm spacers, and at 20mm offset my front tyres do not rub even on full lock.
