rough idle and loss of power 1994 xjs 4.0
Old Feb 26, 2013 | 03:51 PM
Icarrya45's Avatar
Default rough idle and loss of power 1994 xjs 4.0
Hey guys, I'm a new Jaguar owner(father in law gave me 1994 xjs convertible 4.0 for my daughter). It has been sitting for 7 years. I cleaned injectors, replaced idle air control valve, cleaned plugs, new dist.cap and button, cleaned fuel tank, new fuel filter. Car idles very rough, i can hold rpms between 2000-4000 and runs fair. Put a load on it and it falls on its face. Thanks for any suggestions on my problem/s. code FF14
Old Feb 26, 2013 | 05:29 PM
Vee's Avatar
Vee
FF14 = Replace Coolant Sensor.
Old Jun 26, 2020 | 02:47 AM
Justin Barco's Avatar
Default I’m having same issue- did you find a solution?
Old Jun 26, 2020 | 09:55 AM
Vee's Avatar
Vee
Clean the throttle body, it is a must. Take it off the engine and give it a thorough cleaning. (assuming your same problem doesn't have a FF14 code as well?)
Old Jun 26, 2020 | 02:21 PM
XjsBanger's Avatar
Oops... You have AJ16 which is prone to timing chain strech. Especially if the car was sleeping for 7 years. Mind if I ask how you managed to start it up? Was it not started at least once over that time? There is a highly recommended start-up procedure for AJ6, AJ16 and applicable to any other engine...
Daniel Bar-Tal
Sep 8, 2016 06:38 AM
93greenconv
Jul 27, 2014 09:04 AM
Mad Matt
Jun 26, 2014 04:29 AM
jomia092306
Mar 25, 2014 05:46 PM
93greenconv
Nov 28, 2013 11:30 AM
