Sealing washer
Old Aug 27, 2018 | 08:10 AM
reichstall's Avatar
Default Sealing washer
Does anyone know the size of the sealing washer that is in the high pressure line that goes into the rack body on an 88 xjs?
Old Aug 27, 2018 | 09:47 AM
sidescrollin's Avatar
funny, I don't recall there being a washer there. I thought those fittings were pipe thread and didn't use a washer.
Old Aug 27, 2018 | 11:56 PM
warrjon's Avatar
The fittings are flare, there are no washers in a hydraulic system
Old Aug 28, 2018 | 07:02 AM
reichstall's Avatar
Default flare thread
if you look at the side that goes into the block where all the other are it is a standard double flair follow the line down to where it goes into the rack body it is a flat type flare in the body of the rack in the seat there is a washer with a molded rubber oring looking thing. This is my leak it shows in the repair kit which is the route I went for 45 from convert west. .So I will measure and post size for future folks looking. This is the only way I could find to buy this part was the whole kit.
Old Aug 28, 2018 | 04:00 PM
Not necessarily. My MG has copper washers on some brake lines
Old Aug 28, 2018 | 04:01 PM
Originally Posted by sidescrollin
funny, I don't recall there being a washer there. I thought those fittings were pipe thread or flare fitting that don't use a washer.
Richy_T
Oct 10, 2013 11:17 AM
Robert H
May 23, 2013 01:43 PM
AlfaVeloce
Dec 31, 2012 01:00 PM
darren-talbot
Dec 15, 2012 05:46 PM
Sean B
Detailing / Car care
Aug 1, 2011 03:06 AM
