Seat Belt Retract
Old Apr 12, 2012 | 07:49 AM
HeyCharger's Avatar
Default Seat Belt Retract
Hi guys. On my '86 Cabriolet, the seat belts will not tension or auto-retract as they should. I can manually push the belt back, but it is like the spring has weakened. Any solutions? Thanks. Rod.
Old Apr 12, 2012 | 08:04 AM
Doug's Avatar
On other old cars (including Jags) I've had good results by removing the belt assmbly and thoroughly cleaning and lubricating the retractor mechanism. Voilá....the retractor comes back to life!
You might be shocked at how much gunk and debris you'll find.
Don't actually *disassemble* the mechanism. Just unwind it, clean it, and lubricate sparingly
Old Apr 12, 2012 | 08:48 AM
cadfael_tex's Avatar
I have that on my '94 drop top. How do you get to the mechanism? Doug when you say remove but not disassemble the mechanism I'm assuming you mean take it out of the car but not tinker with the internals? What do you use to lubricate it?
Old May 18, 2015 | 07:02 AM
HeyCharger's Avatar
Further to my first post (above), the drivers side has now locked.
Is it hard to get the trim off a Cabriolet (2 seater) to check seatbelts?
Old May 26, 2015 | 06:43 AM
kpeerbacus's Avatar
Default fuel tank unit
Hello how to test the fuel tank unit for jaguar coupe xjs 88 3.6 after remove it?
Old Jun 22, 2015 | 06:49 AM
talulah's Avatar
Just done this myself (although didn't have to take the whole thing out). Pics and instructions can be found here: Seatbelt
Poet
Feb 7, 2025 02:18 PM
bdboyle
Sep 16, 2019 05:58 PM
magmedia
Aug 15, 2019 08:54 PM
GGabriel
Nov 22, 2018 03:53 AM
BlacXJRcat
Sep 25, 2015 06:43 PM
