Seat belts
Old Mar 30, 2017 | 02:03 PM
john rainford's Avatar
Default Seat belts
I just purchased a 1994 xjs 4ltr six cylinder five speed convertable and had to purchase seat belt extensions as the seat belts were two short to fasten I am not overweight and the dealer checked that the seat belt was not being trapped hard to understand car is totally stock? Thank you John Rainford
Old Mar 30, 2017 | 02:54 PM
Welcome to the forum John,
I've moved your question from General Tech Help to XJS forum. Members here with the same model will know if this is a regular issue or if the vehicle could have been fitted with the wrong belts.
Old Apr 3, 2017 | 11:17 AM
sidescrollin's Avatar
I dont think I can give you any helpful specs to compare because I have a pre-facelift '88 and it has the stupid automatic belts. Probably too different to compare.
That being said I can't imagine then being too small for anyone and I often have a problem with it being too big because the top shoulder portion is so old it is dried and doesn't like to tighten down all the way.
Maybe someone with a facelift car can chime in and tell you their lengths so you can determine whether yours really is functioning properly.
Old Apr 3, 2017 | 12:24 PM
malc4d's Avatar
Take off the rear interior panels and check that the belt is coiled up correctly. Never ever believe that a car salesman has fixed anything....! Unless you saw them do it.
Old Apr 3, 2017 | 02:04 PM
Vee's Avatar
Vee
John,
Which belt was too short? Drivers side shoulder, lap, or both?
Have you tried the passengers seat?
I'll measure the one in my 96, but I suspect there's an issue here.
Old Apr 3, 2017 | 08:44 PM
Some Day, Some Day's Avatar
I have a facelift, and I'm not a small guy by any means, and it's a Japan model (which might indicate shorter seatbelts), and don't have any problems. You definitely don't have standard. I think malc4d is right--your dealer probably gave it a few half-arsed tugs and said "nah, she'll be right mate."
Old Apr 14, 2017 | 03:07 PM
malc4d's Avatar
So...hows it going fixed ?
Old Apr 14, 2017 | 05:35 PM
I don't know if OP will ever return, but if he doesn't, you can post him a letter instead - his location shows his full street address, which is also something he might want to fix....
