Should I use an RCB Breaker with a Welding Set?
Old Mar 3, 2024 | 12:46 PM
orangeblossom's Avatar
Default Should I use an RCB Breaker with a Welding Set?
Hi Guys
Made some good progress on the Battery Charging front but more of that later as its Tea Time!
But meanwhile does anyone know if I should use an RCB Breaker
On (A) Welding Set?
And or
(B) Battery Charger?
Or is there too much Chance of Tripping the RCB Breaker?
Old Mar 3, 2024 | 01:07 PM
ptjs1's Avatar
OB,
You only really need an RCD if you think there'll be a problem either through circuit overload or short circuit etc. It's used to protect the appliance and to protect the integrity and safety of your wiring electric supply. A standard battery conditioner won't need one. It will already have overload circuitry etc. If you think you've got an internal problem with that welder, I would definitely try and fix it before plugging it in.
Paul
Old Mar 3, 2024 | 01:23 PM
Hi Paul (ptjs)
I think I found the problem with my 'Vintage' Welder Battery Starter Charger. I'll put some Photos on my Cherry Blossom Thread to show what I did and was also thinking along those very same lines
orangeblossom
Mar 3, 2024 06:05 PM
Jjdejd
Feb 10, 2024 02:15 PM
orangeblossom
Oct 19, 2022 11:26 AM
xjack
May 9, 2020 06:21 AM
JCHouston
Feb 12, 2016 11:08 PM
