Single coil retro fit
Rex,
I believe so.
That module inside is OK with UP TO 0.9ohms, or thereabouts.
At 1.0ohms, it basically fries, from my own car findings.
I run a Fuelmiser CC215, OK, I;m down here, you are not.
Memory? it sat at 0.7 Ohms Cold and 0.8 Ohms Hot.
It is classified as a "Universal Electronic Ignition Coil" by Fuelmiser. I also use it on the S3 6cyl, and the XJ40 AJ6, no issues.
My AB14 is out the front of the radiator on all the V12's. Nice and cool.
I believe so.
Rex,
Yes o the 1st.
NO to the 2nd, since that wiring basically ran up the inner guard channel, nowhere near any HT interference stuff.
BUT
I did pick up the OE shielded wire inside the wheel arch cavity, and carefully connectoe "my" wire to that inner core, and insulated it very well. It was still extremely soft and pliable in there, away from the engine bay heat.
Some say that coax COULD have the shielding earthed at the ECU OR the Amp. All the ones I have been into are earthed at the ECU, so maybe other markets got weird stuff, dunno. It is only earthed at ONE end no matter what.
Yes o the 1st.
BUT
wnlewis
Apr 2, 2009 10:17 PM
