A slight stumble
Old Dec 30, 2008 | 09:53 AM
i_like_ike's Avatar
Default A slight stumble
Just did plugs cap and wires on my 89 v12 and WOW does it run like a top! However, just as you start to crack the throttle open, it has a (very) slight stumble before it picks back up. Any suggestions?
Now part 2: I noticed the old distributor cap had a vaccum line going into it which I plugged off because the new cap didn't have holes drilled in it (and I was too lazy to do it). I assumed it was just to keep it dry inside. Is this assumption correct or am I going to have to go dive back in to fix my own mistake?
*Important tip to Jag new comers...DON'T WORK ON AN XJS WITHOUT HAVING A MAGNET IN YOUR TOOL BOX*
Old Dec 30, 2008 | 10:54 AM
Doug's Avatar
Default RE: A slight stumble
Dist cap: that a breather/vent hose to vent fumes out of the distributor. Unless someone has removed it you should see the "other end" ....the fresh air inlet....tie wrapped tp the left fender brace with a small filter attached (looks like a lawnmower fuel filter).
I really wouldn't want to run without one. There are known cases of dist caps blowing apart.
Hesitation: Lots of possibilities but here are a couple of basics which can be elaborated on if you need help...
1) at the rear of each head there's a bellcrank like throttle linkage. Make sure the plastic bushing haven't rotted away. If they have then the throttles won't open in unison
2) clean the throttle bodies and make sure the throttle bladesare set at the proper .002" gap
3) synchronize the throttles using the provided adjustments on the rods. I can suggest a method if you need help
4) make sure you vacuum advance cannisteris working and that the advance mechanism inside the distributor hasn't seized up (rotate the rotors and release...it should snap back "smartly")
If none of this helps.....and its all stuff that needs to be looked at on general principle anyway....we can talk about throttle position sensors
Old Dec 30, 2008 | 11:07 AM
Doug's Avatar
By the way, what kind of dist cap did you buy? I've never seen one without the nipple for the vent hose. Just curious
Old Dec 30, 2008 | 11:13 AM
ArmyJag's Avatar
ORIGINAL:doug I really wouldn't want to run without one. There are known cases of dist caps blowing apart.
Wow, now that is cool
Not questioning the knowledge on that Doug, I just thought, I would never find stuff that surprised me more than land rover quirks.
Old Dec 30, 2008 | 11:21 AM
Doug's Avatar
I think all Brit cars are quirky. Double that for older Jags. Triple it for the XJS V12 !
Depending on your frame of mind that's either "part of the fun" or "a pain in the a** "
Old Dec 30, 2008 | 11:35 AM
ArmyJag's Avatar
If you can't look at an exploding dist cap as fun then your probably driving the wrong brand of car
Old Dec 30, 2008 | 11:50 AM
Doug's Avatar
ORIGINAL: ArmyJag
Perfect. I'm gonna rmeember that. I think you've summed up the entire "old Jag ownership thing" in one simple sentence.
I can see that you're a true "Jag-man"
Old Dec 30, 2008 | 01:02 PM
i_like_ike's Avatar
Thanks Doug, I checked the vaccum cannister when I had it all apart and I thought its response was a little sluggish. I guess I'll be going back after it later in the winter.
n2audio
19
Jan 20, 2025 09:35 PM
studentper
Feb 20, 2016 09:43 PM
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
mat32essex
Oct 3, 2015 04:12 PM
n2audio
Oct 1, 2015 01:54 AM
