Sound system question XJS V12 1990
Old Feb 5, 2013 | 06:28 PM
orangeblossom's Avatar
Default Sound system question XJS V12 1990
Hi My XJS V12 has got the pull out radio/tape which may have been great back in the day but now I want to up grade it to a Stereo/Radio/CD.
I want to do the job myself, so can anyone who has done this, please tell me the best way to go about it.
Old Feb 6, 2013 | 03:07 AM
warrjon's Avatar
First you need to decide on what is going to in there. Features etc
When you have made your purchase installing it relatively easy as long as you have some basic skills and tools.
You will need
DMM
wire cutters
pliers
Soldering iron - I prefer to solder all connections rather than use those horrid cheap crimp connectors as they always come apart DO NOT just twist the wires together.
Once the old one is removed you need to identify where all of the wires go so they can be connected up to the new head unit.
=== edit === Oh you will need heatshrink tube to cover the wires
Old Feb 6, 2013 | 07:51 AM
Hi Warrjon
Many thanks but the bit that I really wanted to know was: do I need to remove the steel casing that the slide in unit slid into, or should I leave that in place?
Old Feb 6, 2013 | 08:25 AM
mefoote's Avatar
You'll need to remove the steel cage, and replace withth eone you get with you new head unit, as each have different locking arrangements.
a flat headed screwdriver should prise the soft metal tongues up and it's a five min job to put the new one in. Just done myself.
Old Feb 7, 2013 | 05:28 AM
Hi Mefoote
Many thanks. I was a bit dubious about taking the old cage out as I wanted the option of going back to retro if I wanted.
So although I haven't done the job yet it sounds a piece of cake.
1100me
Aug 27, 2020 11:37 PM
Doug S
Sep 10, 2015 01:53 PM
that7dude
Sep 2, 2015 11:55 AM
rmbtl2
Aug 26, 2015 08:52 AM
