Speedometer angle drive behind dash
Old May 17, 2020 | 10:27 PM
CZSteve's Avatar
Default Speedometer angle drive behind dash
My speedometer has gone out on my '78 XJ-S; bouncing back-n-forth between keeping the stock instrument gauge assemble VS going with a customer aftermarket gauge panel.
Symptoms: Upon recently getting the car the speedometer was jumpy up to ~ 30 mph and then one day quit altogether driving home; I'm 99% it's the angle drive behind the dash. The angle drive at the transmission is fine and today I was able to reach up below & behind the dash to unscrew the mechanical cable to the angle drive behind the dash/gauge - gauge end of the cable rotates fine while driving.
I plan on pulling the instrument panel to replace the bulbs and contemplating picking up an angle drive in advance if I can to knock everything out relatively quickly at once.
An eBay query comes up with different model numbers - e.g. BG2413/60, BG2410/60 and BG2410/20 - maybe other?
Anyone know correct angel drive for behind the gauge for a Left-Hand drive 78 XJ-S?
Thanks, Steve
Old May 17, 2020 | 10:44 PM
Doug's Avatar
The original Jaguar number is C38925. You might Google that and see what happens
Also, I think Bernie Embden has a write-up about these drives on his web page
Bernard Embden's Jaguar Website
Old May 18, 2020 | 07:43 AM
CZSteve's Avatar
Thanks Doug - Yes, I'm familiar with Bernard's site and absolutely love all the information he's posted; it's a regular for info and ideas.
I don't get much Googling the part number he references; I use with and without dash after the 'C' - I did come across a BG2410/40 that was posted on an UK eBay site (assuming that would have been for a right-hand drive XJ-S.
I've seen where he first looked to modify for a perpendicular cable approach to omit the angle drive and then swapped over to a later electronic version which I was also contemplating; instead of going the stock electronic version I'm also contemplating going full aftermarket w/ a custom instrument panel - first choice to limit initial cash outflow is to see I can source another angle drive and thus focus on other projects for the time being.
Any thoughts on the differences the part numbers of BG2410/60 and BG2410/20?
Any speedometer repair folks anyone can recommend to repair the existing angle drive?
I'm presuming the problem is an internal gear where the teeth wear down? Yes? No? Other?
Thanks again for any input.
Best, Steve
Old May 18, 2020 | 07:47 AM
Robert Laughton's Avatar
Hi Steve,
I have a few dashes and a whole car for parts.
The angle drives turn. There's no part number on them
I'll sell the drive(s) an/or the whole dash(s) for what ever you think is fair.
Good luck,
Rob
Old May 18, 2020 | 08:07 AM
Oops, there are part numbers. I had to wire brush the area.
Both of these are BG2410/40
Old May 18, 2020 | 08:52 PM
CZSteve's Avatar
Originally Posted by Robert Laughton
Hi Steve,
Good luck,
Rob
Hello Robert -
PM just sent if you don't mind RE your angle drive.
Thanks again and best,
Steve
Old May 19, 2020 | 03:53 AM
leo_denmark's Avatar
Thanks for that link ! Brilliant page, especially for us PreHe owners
I have exactly same issues and thought I just needed a new speedo cable. Now I'm better prepared...
CZSteve
May 15, 2020 02:26 AM
Sean W
Sep 3, 2018 03:46 AM
97XJR-Flausa
Jul 19, 2015 11:20 PM
gmachinz
Jun 23, 2014 05:40 PM
