spun rod bearing :( need parts ASAP
Old Jan 28, 2013 | 05:38 PM
calvindoesntknow's Avatar
Default spun rod bearing :( need parts ASAP
so i had my xjs out, and i spun a rod bearing, havent gotten the crank case apart yet to see what was the cause. but i will need the following parts if posible from anyone on here, for work i will be doing while the motor is out.
Crankshaft & rotating assembly (possibly)
rod and main bearings,
gasket kits.
Rear end/ differential for rebuild with 3.54 gear
rear suspension bushings
if anybody has any of these parts for sale, let me know! thanks
Old Jan 28, 2013 | 08:14 PM
M90power's Avatar
youre definitely gonna want to replace whatever rod that spun the bearing. so youll need at least 1 rod.
Old Jan 28, 2013 | 08:47 PM
two bearings spun fully, others were worn pretty bad. im looking into having it offset ground and pulling a lot more liters out of it. anyone have any info on this?
Old Jan 29, 2013 | 03:42 AM
warrjon's Avatar
gasket kits.
You won't need to replace the crank, although if you could find an EN40 forged from a 6.0L it would make life easier. These are even harder than the 5.3 crank. Be aware though that the later 6.0L used a cast crank.
You can offset grind see my post in your other thread.
Just remembered Ian's car take a look at this
XJ-SC Modifications
Old Jan 29, 2013 | 11:05 AM
What rods would i use?
Old Jan 29, 2013 | 02:07 PM
warrjon's Avatar
Chev 6.0" I beam you will need to do some machine work on the bigends to narrow them and small end for a floating pin.
something like these they support 500hp in 8 so 750hp in 12
Eagle Specialty Prod Connecting Rods SIR 5140 I-Beam Press Fit Chevy SB SetOf8 | eBay
Old Jan 29, 2013 | 04:58 PM
ronbros's Avatar
i have used welded crankshafts before , some work out fine,as long as you dont stress them, or RPM them, but others have cracked into pieces after a short time of racing use.
some times, in the welding process,very small heat cracks are done,BUT hidden under the welding layer. so magnafluxing it doesnt show.
an early 6.0L crank forged steel,would be my chioce, again realisticly, a good later 6.0L cast crank would more than do the job,FORD knows a lot about nodular casting processes, lotsa yrs at it!
and all&all get ready to spend some serious MONEY, you know,,custom pistons, full set of good rods, good engine bearings sets, ETC.
last but not least ,find out WHY the engine spun a bearing, you may have other problems that need to be addressed!
PMKimpton
Aug 3, 2019 08:22 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
innzane
Sep 2, 2015 10:08 AM
