macdoesit
Banned
close
- Join DateDec 2012
Liked:262 Times in 169 Posts
Turned ignition off took out key and steering no longer locks and you can put in R,N,D without pressing brake also you can put in any gear without key in ignition and no foot on brake. I have not mucked with anything it just happened.
Could steering possibly lock up while driving ?
Grant Francis
close
- Join DateFeb 2010
- LocationAdelaide Stralia
Liked:11,269 Times in 7,438 Posts
Maybe our cars were different, but I do NOT recall a gearlever interlock in the Pre 1994 cars. Maybe the US of A cars got it, no idea why.
I thought it only arrived with the J Gate system.
The steering lock is possibly just a gummed up plunger in the barrel, after all it is OLD now. Remove those 2 shear bolts, and lube that plunger, refit with new shear bolts, or standard bolts.
Panic not, she will know, and mess with your head even more.
macdoesit
Banned
close
- Join DateDec 2012
Grant, thank youOriginally Posted by Grant Francis
Maybe our cars were different, but I do NOT recall a gearlever interlock in the Pre 1994 cars. Maybe the US of A cars got it, no idea why.I thought it only arrived with the J Gate system.
Steering used to lock
What about the shifter ?
Doug
close
- Join DateMar 2008
- LocationPacific Northwest USA
Liked:11,712 Times in 7,580 Posts
Quote:
Are you sure it hasn't been that way all along?
Might just be wheel position. Have you tried removing key then turning wheel a little in either direction until locking mechanism slips into engagement?Originally Posted by macdoesit
Turned ignition off took out key and steering no longer locks and you can put in R,N,D without pressing brake also you can put in any gear without key in ignition and no foot on brake. I have not mucked with anything it just happened.Could steering possibly lock up while driving ?
l can only speak for the V12 cars l have, none of them have any form of gear lockout.
Grant Francis
close
- Join DateFeb 2010
Quote:
I reckon he is still on the New year Juice, COFFEE Mac, LOTS of it, and maybe the Jag will appear as it should.Originally Posted by Doug
Are you sure it hasn't been that way all along?Cheers
Grant Francis
close
- Join DateFeb 2010
Gearshift lever, is NORMAL as far as I am concerned. Sure your not confusing the Jag with a Korean monster????????Originally Posted by macdoesit
Grant, thank youSteering used to lock
