Steering Rack - Pipe Supports
Old Aug 27, 2024 | 12:50 PM
BenKenobi's Avatar
Default Steering Rack - Pipe Supports
I have misplaced the supports for the power steering pipes, they're like two towers that fit both the rack and the pipes - does anyone have one to hand that they could measure - see image - I can draw up a template if it helps
Old Aug 27, 2024 | 01:14 PM
ptjs1's Avatar
Ben,
I can't help on measurements, but if you need to source one, that's a very old parts diagram you're looking at for the earlier cars. By the time yours was built, the part number was CBC 2136.
PAul
Old Aug 27, 2024 | 01:27 PM
BenKenobi's Avatar
Like many things now showing no longer available so my only options are find secondhand ones, make new ones, launch a timewasting clearance of my black hole garage that is constrained by two cars - one of which has no wheels and no rear suspension - aka the XJS - the other car is blocked in by - yes you guessed it the XJS - I have better things to do than waste 'useful' days tearing the garage apart. Consider I took these off three years ago and many many parts have been moved more than once - I should have been more organised but hindsight is a bit of a bitch - like all the pictures I took - guess which pictures I didn't take - if you guessed the ones I really need pour yourself a drink of your choice.
None of my usual sources have these things - you wouldn't think there would be a demand for them - clearly there is.
egold56
E type ( XK-E )
Jan 10, 2023 08:23 PM
BenKenobi
Jul 21, 2022 11:50 AM
brinny
Jul 21, 2022 10:45 AM
darylSeven
XJ40 ( XJ81 )
Nov 12, 2021 11:56 AM
Rique
Oct 2, 2009 03:19 PM
