steering wheel adaptor
Hi everyone. Just tried to install brand new wood/leather steering wheel in my XJS 95 convertible but have met the problem. The new wheel i've got is made for European/UK market and doesn't fit for my US market car so it seems like i need to get and change steering wheel adaptor (JLM12391 86 teeth) that absolutely impossible to find. Any suggestions about where to get one? Also how can I extract existing adaptor from steering column to try to reproduce it in size i need?
Thanks to all.
Thanks to all.
Just check that there isn't already an adapter in the wheel you took off. I thought i had the same problem then found that there was a small adapter spline inside the old airbag steering wheel.
reedreed,
I have sent you a couple of PMs over the past few weeks to see if you're interested in swapping your adapter for the one that you need which I have. I don't know if you've seen these?
Paul
Paul
When l changed mine over I found the adapter was used in the XJ40.
http://www.jaguarclassicparts.com/uk/part/JLM12391
But I'm guessing as they haven't replied they've found it.
FS[SouthWest]: Momo Wooden Steering Wheel
RobertTheBloke
Sep 24, 2015 11:48 AM
1964Daimler
Sep 9, 2015 11:28 AM
