Sticking Gas Pedal
Old Mar 15, 2014 | 10:24 AM
Spikepaga's Avatar
Originally Posted by AllanG
Sure you can test it, it is just a potentiometer. Using a voltmeter with the ignition on but engine not running, back probe the wiper wire at the connector. At idle you should see about 0.6v. Then slowly rotate the throttle quadrant and observe that the voltage increases steadily and smoothly with no flat spots. At WOT you should have a reading of around 4.8v if I remember correctly.
The wipers do wear over time and yes there could be ingress by oil or cleaning agents that could create a short but this test be an effective way verify the functionality of the TPS
Well, that very test was done on my faulty TPS many times....and the car kept on dying at 60mph in the highway. I don't know if it started acting up because of the heat or what, but every time I hear of a AJ16 car that is cutting out at high speed and the TPS is suspect , my advise is always to replace. 300 or 400 bucks is not worth causing an accident.
Old Mar 15, 2014 | 12:36 PM
RagJag's Avatar
Good advice. Spikepaga.
max224
Jun 21, 2024 12:17 PM
jagtoes
Oct 14, 2015 06:15 PM
pnwrs2000
Sep 30, 2015 01:56 PM
dansxj6
Sep 28, 2015 08:02 AM
