testing the tach
Old Nov 30, 2018 | 08:56 AM
J_C_R's Avatar
Default testing the tach
1987 XJ-S V12
Tach seems to have died.
Polking around the web, it doesn't seem that there is an easy way to test it. Of course maybe *today's* tachs are more sophisticated than those of 1987.
I feel I need to test two things, the signal coming from the ignition amp, and the tach itself, to nail down the problem.
Any suggestions?
Thanks,
John
Old Nov 30, 2018 | 09:14 AM
Doug's Avatar
Besides the signal from the ignition amp the tach also needs 12 volt "key on" power and needs a ground. Any or all of the three might be compromised by poor contacts at the cluster connector or printed circuit. Problems here are common, as we know
If all three are OK then the problem can only be the tach itself
Testing is easy in theory; simple test light or meter will suffice. Access gets a little tricky
Old Nov 30, 2018 | 12:34 PM
J_C_R's Avatar
Doug,
Should have been more detailed in my post. Tach has continuity to ground and is getting +12 at the proper terminals.
There is no more printed circuit in mine. I'm in the process or hard wiring everything. All the instruments are done, and work as expected, except the tach. Since I did nothing to it (didn't even dismount it from the instrument housing) I'm confused why it worked before, but doesn't now. Then again, this won't be the first time something broke because I looked at it wrong.
Given the price of a "new" one, I just want to make sure I'm getting the proper signal from the ignition amp. Do you know how I can test that?
Thanks,
John
Old Nov 30, 2018 | 02:04 PM
warrjon's Avatar
A multimeter on AC volts can be used to verify the tach signal. Don't know what voltage you should expect but I would guess a few volts. If the meter has Hz function even better, the frequency should go up as you rev the engine.
IB Nolan
Aug 6, 2013 06:28 PM
globalxgear
Apr 18, 2008 07:40 PM
globalxgear
Apr 4, 2008 07:45 PM
Dec 23, 2005 02:55 PM
