Is there an electrician in the house?
Old Aug 23, 2016 | 10:33 AM
JigJag's Avatar
Default Is there an electrician in the house?
I want to modify my TPS. Adjustment of this unit is too difficult, too imprecise and mine appears to vary over time slightly.
My plan is to raise the TPS setting to about 1V above the prescribed voltage and add a modern trim potentiometer and 2V meter to the circuit. This way I can easily adjust the voltage to spec. The TPS will function as normal but with it's resistance slightly augmented by the pot.
What I would like to do is order the correct ranged potentiometer. Does anyone here know how to spec a pot to a 12V system that would give me a 1-2V variance? If not, I suppose I can always pick up a range of them and do some science on it.
Edit: I guess I can change the setting on the TPS to be 1.34V, meter the TPS ohms, reset it and re-meter the ohms, take the difference and get a potentiometer that provides approximately double that resistance.
Last edited by JigJag; Aug 23, 2016 at 12:08 PM. Reason: Corrections and possible solution
Old Aug 23, 2016 | 02:46 PM
swayne's Avatar
Default Tps
If useing a digital multimeter while adjusting Tps try using an analog meter adjustment want be as sensitive
Old Aug 23, 2016 | 06:12 PM
warrjon's Avatar
The way the TPS works is a voltage divider, the ECU input will provide the fixed side of the divider R2.
The equation to work out the voltage is.
Vout = Vin*(R2/R1+R2) so R1= Vout / (Vin*R2 - Vout *R2)
Where R1 is the TPS and R2 can be your trim pot.
SO lets put some nominal values
R2 = 10ohms
Vin = 12volts
Vout = 2volts
R1 = 2 / (12*10 - 2*10)
R1 = 2/ 100
R1 = 50ohms
To complicate things, if you put a trim pot it will be in parallel with the ECU R2 so these resistances add like this R2trim and R2ecu
R2total would be this 1/R2total = 1/R2tim+ 1/R2ecu
So you can see if you double the pot resistance it will not double Vout.
I know this can be confusing, this is why an electronics qualification takes years.
Hope this helps
Old Aug 24, 2016 | 02:36 PM
JigJag's Avatar
Warren,
This is great! Thanks for the electronics lesson. I'll let you know how it works out!
SD96XJ6L
Dec 17, 2019 11:15 PM
Jandreu
Aug 20, 2016 06:04 PM
Gerry755
Aug 9, 2016 08:10 PM
orangeblossom
Aug 5, 2016 07:39 PM
Mark SF
Jul 14, 2016 11:48 PM
