Throttle Body Stepper Motor Help Needed
Old Oct 18, 2020 | 03:37 PM
coldpad1's Avatar
Default Throttle Body Stepper Motor Help Needed
96 xjs 6 cylinder. Is there an easy way to test or determine if the throttle body steeper motor is working properly?
Old Oct 20, 2020 | 07:20 AM
Vee's Avatar
Vee
Depends what the problem is.
HIgh idle?
Old Oct 20, 2020 | 11:42 AM
coldpad1's Avatar
Default Idle speed control valve
erratic idle...foot off gas and surges up and down. Got a code the other day idle speed control valve but mechanic said he found a vac hose off and now check eng light is out. Here's the thing... I see aftermarket ones on ebay for $15, but a lucas part is $195. I don't mind spending the $ for the Lucas if I was sure thats the issue. Wondering if I should buy the cheapo to see if it helps and then buy the good stuff it is the issue. Then I wondered if there was a way to test mine for being good or bad.
Old Oct 21, 2020 | 06:39 AM
Vee's Avatar
Vee
I' d start with the aftermarket. $15 is worth it, no? Then if it starts to fail in 6 months, you can invest in the pricier version.
Crandell
Mar 21, 2019 11:44 PM
Addicted2boost
Dec 18, 2016 02:48 PM
fredd60
Jun 24, 2013 12:04 PM
PattertiXK8
Nov 28, 2012 12:14 AM
Vic Douse
May 4, 2011 06:35 PM
