throttle grommet v12
Old Sep 14, 2013 | 11:33 AM
motomental's Avatar
Default throttle grommet v12
Is there a trick to installing those hard throttle linkage grommets
Old Sep 14, 2013 | 12:46 PM
JTsmks's Avatar
Mine popped right in, try heating them up a little and a little lubricant.
Old Sep 14, 2013 | 01:12 PM
Doug's Avatar
I've had some aftermarket bushings that were SO hard I simply could not insert them into the holes at all, even with het and lube. I had to trim 'em a bit....which sorta defets the purpose.
Next time I go with the original material or, more likely, the door hinge bushing substitute mentioned here a year or two ago
jimforrest (uk)
Feb 28, 2019 06:42 PM
tomkilner
Oct 9, 2015 07:10 AM
inactualis
Oct 2, 2015 11:13 AM
42Ajd
Sep 26, 2015 07:04 PM
