Transmission solenoid wire (GMT400)
Alas when installing the engine/transmission I caught the transmission solenoid wire at the transmission end and pulled it. I have the solenoid end connector and little over 2 ft of wire
It pulled hard enough to extract it from its protective covering.
I can't find a good answer so I'll ask
where does the other end of that wire go? It kind of looks like it goes up into the shifter area?
Thanks!
It pulled hard enough to extract it from its protective covering.I can't find a good answer so I'll ask
where does the other end of that wire go? It kind of looks like it goes up into the shifter area?Thanks!
That makes sense - what was fooling me is that I already had a green and a yellow/green wire on the full throttle microswitch those go down into the valley into a harness. Suggests my breakage is inaccessible without heroics. Since I will need to rewire the solenoid side anyway...read this post on another forum maybe I go ahead and do this? https://forums.jag-lovers.com/t/xj-s...tment/330927/5
My understanding please correct if I am wrong!
The microswitch on the pedestal itself is also related to the blue throttle control valve for full-ish throttle enrichment. The second microswitch is part of a mechanism on the throttle cable that only engages when the gas pedal is mashed to the floor and that switch is what engages the transmission solenoid (?).
JeffR1
Sep 23, 2016 01:27 PM
