Transmission woes - how easy is it to ?
Old May 27, 2013 | 02:48 PM
Gasgasbones's Avatar
Default Transmission woes - how easy is it to ?
Hi guys
XJS 3.6 auto
I think ( I know ) I've got a leak of transmission fluid from around the transmission bits and bobs.
Looking underneath I see a box shaped item which is probably a sump as the filler pipe leads into this. At the side of that there is drum shaped thing ( with a little rubber thingy stuck in it )and I seem to be loosing fluid from around there, the drum.
The questions are ???
1) What's the drum shaped thing with a rubber thingy in it?
2) How easy is it to fix the leaks with the whole unit in situ.
3) Would the lack of fluid prevent the car from going into gear ? I'm presuming yes !
I can add pics if needed.
Thank you
Carl
Rlover
Mar 30, 2016 10:04 PM
Poet
Oct 6, 2015 09:40 PM
Will P
Sep 30, 2015 08:38 AM
chatmanx
Sep 11, 2015 07:17 PM
Broken_Spanners
Sep 6, 2015 11:34 AM
