Trim issue
Old Sep 17, 2014 | 01:02 AM
notmyjag's Avatar
Default Trim issue
I'm working on a 85 XJS for a customer and his lower chrome windshield trim is loose. How is this supposed to be held on? It's the drivers side lower corner. Thanks for any help... Dan in ND.
Old Sep 17, 2014 | 02:40 AM
Welcome to the forum Dan,
I've moved your question from General Tech Help to XJS forum. Members here with the same model will be able to help.
I hope you plan on sticking around. If so, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Sep 17, 2014 | 03:55 AM
Greg in France's Avatar
It is best to remove the trim and re-do it. I am not clear if you are referring to the A pillar trim, that goes round the bottom corner of the windscreen, or the piece that runs along the bottom. Either way, this is the drill:
  • Pull back the A pillar rubber seal a bit, this will reveal two rivets or screws holding the A pillar trim, undo/drill out these
  • Gently ease off the trim (it is stainless steel by the way, so quite robust) and also gently pull it of of the windscreen rubber groove, carefully unclipping it where it is over the gutter at the top
  • This then reveals the screw holding the end of the windscreen bottom trim, and possibly a deal of rust too at the bottom corner
  • Then fettle/bend the trim until it seems to lie as you want it to
  • apply a goodly bit of seam sealer to the underneath so it is stuck in place as far as possible, and re-attach and fixings you undid.
If it is the trim along the foot of the screen, and you need to remove that completely, as well as undoing the other side pillar trim, you need to undo and remove the windscreen wiper mechanism and grille to get at two centre trim fixings hidden by the wiper stuff.
Greg
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Rivguy
Dec 4, 2020 07:55 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
