Trouble with Delanaire ducting/heat
Old Dec 30, 2021 | 03:05 PM
taperguy's Avatar
Default Trouble with Delanaire ducting/heat
I am working on a 1990 Jaguar XJS Convertible. The problem has to do with ducting warmed air to the middle//upper tier of the system. I cannot get any warm air to either the center side vents or the defroster vents at the top of the dash. This while the lower vents in the knee area are blowing heated air strongly.
The air speed also seems anemic at the side vents although stronger at the top vents (defrost) than the sides. The temperature selected is the highest (when the temp knob is all the way clockwise) and the knee vents are blowing accordingly, but I am getting A/C cold from side and defroster outlets.
Old Dec 30, 2021 | 05:08 PM
taperguy,
I've moved your question from General Tech Help to XJS forum. Members here with the same model will be able to help.
Dick
Feb 7, 2019 04:41 PM
JessN16
Dec 9, 2015 11:25 PM
nikmott
May 7, 2014 05:18 PM
psmith994
Jun 18, 2013 10:54 AM
Fyrplg
Jun 14, 2012 02:26 PM
