V12 flex plate removal
Old Apr 3, 2013 | 01:00 AM
Per's Avatar
Per
Default V12 flex plate removal
The V12 flex plate is bolted to the crankshaft. In addition there are two inserts for the bolts holding the "bar" for the nut used to twist the crank by hand. these two inserts are holding the flex plate onto the crank shaft, or so it seems. Any idea how to release the flex plate?
Old Apr 3, 2013 | 03:54 AM
Yep.
1) Find some long fully threaded bolts (we call them set screws) that fit the threads, and NO, my memory is simply not that good.
2) Find something to slide between the crank flange and the cylinder block, I used a piece of wood.
3) Thread those bolts (setscrews) in and slide the wood in, and keep winding. The end of the bolt/s will contact the wood, keep winding, the thread thingy will come out. They will be TIGHT, so patience will be your friend.
There may be other ways of doing this, but that worked for me many times.
Old Apr 3, 2013 | 04:54 AM
Per's Avatar
Per
So if I understand you correctly the inserts are simply a tight press fit?
Old Apr 3, 2013 | 05:23 AM
YEP, and TIGHT is sometimes an understatement.
Old Apr 3, 2013 | 07:03 AM
Per's Avatar
Per
Thanks, brute force then .....
Old Apr 3, 2013 | 09:12 AM
Mish_Mish's Avatar
NO WOOD, no sliding behind crank anything, stay out of the period.
Take 14 mm socket and thread that puller bolt through that socket, into the pilot bushing. This should pull that bushing out and into socket very easily.
Old Apr 3, 2013 | 09:38 AM
calvindoesntknow's Avatar
guys if you take bolts with long threads and twust them in they push the flex plate off. its how I did it
FrickenJag
Jun 16, 2025 02:15 PM
Daim
Nov 28, 2016 09:28 AM
user 652867429824
Oct 28, 2015 10:18 AM
prettydaim
Sep 10, 2015 04:27 AM
1964Daimler
Sep 9, 2015 11:28 AM
