vapor seporator
Old Feb 20, 2013 | 12:12 PM
rgp's Avatar
rgp
Default vapor seporator
vapour separator
i want to fit a proper breather system to the fuel tank on an 84 xjs. i have
a racing 2 way breather to fit into a breather pipe that goes straight to atmosphere that opens when negative pressure of 0.08 Psi (0.0055 Bar) is reached. If the tank should become pressurised then the valve will open to vent if the pressure reaches 0.725 Psi so when i discard the charcoal filter which is in the r.h. rear wheel arch i will have the choice of 3 redundant pipes,
can any of you racing guys remember which pipe is best for this?
Old Feb 21, 2013 | 02:51 AM
Greg in France's Avatar
Originally Posted by rgp
i want to fit a propper breather system to the fuel tank on an 84 xjs. i have
a racing 2 way breather to fit into a breather pipe that goes straight to atmosphere that opens at .02lb poss or neg pressure so when i disgard the charcoal filter which is in the r.h. rear wheel arch i will have the choice of 3 redundent pipes, can any of you racing guys remember which pipe is best for this?
Does not matter. But best to choose the highest outlet on the tank. To check it is clear, put a pipe on it, tape over the others, open the filler cap and blow.
Just in case you are unclear on the setup after the VS, it is like this, as it is maybe best not to vent the new valve into the boot! On UK spec cars the output from the vapour separator goes through a Rochester valve (small black 1.5 inch diameter) which is further into the tank recess/RH wheelarch behind the vapour separator, easier to see once the VS is removed. The output pipe from the VS connects to this valve which is the factory version of what you have just bought. This Rochester valve goes into a long thin metal pipe that runs across the floor at the back of the tank and out to vent below the car, just in front of the cage on the UK passenger side. If this pipe is clear, or can be cleared, hooking up your new valve to it is a good plan.
The pipe can be seen easily in this photo:
Greg
Old Feb 21, 2013 | 03:43 AM
rgp's Avatar
rgp
thank you greg, thats exactly what i needed to know,
rgp
daro31
Aug 27, 2015 09:26 AM
bojangles
Aug 2, 2009 09:38 PM
XJ40ish
XJ40 ( XJ81 )
Aug 1, 2007 01:54 PM
Jul 23, 2005 12:07 PM
